better lens
savage
better lens
Post by savage » 29 Mar 2015, 20:23
is there a better lens on the market for the kpc e700 than what sure24 have on it.
Re: better lens
Post by some bloke » 29 Mar 2015, 20:33
Yup - it's a 25mm one with broadband coatings that benefit IR wavelengths.
It also has some 'free' mag which allows you to wind down the scope mag a bit to let a wider scope exit pupil focus a better image to the sensor. Google 'exit pupil for a better explanation than I can give for that.
http://www.ebay.co.uk/itm/111474879929
savage
Re: better lens
Post by savage » 29 Mar 2015, 20:53
I c the aperture is f1.8 on that lens. Will that effect the distance of what I can see. shooting at range with this kit.
Re: better lens
Post by some bloke » 29 Mar 2015, 21:03
savage wrote:I c the aperture is f1.8 on that lens. Will that effect the distance of what I can see. shooting at range with this kit.
I have to say I dont know the aperture size of the 16mm Sure24 one but by turning down the mag a bit you should logically see further.
savage
Re: better lens
Post by savage » 29 Mar 2015, 21:19
:thumbup: I see what u mean. Iv ordered a cheap one from china which states it's a f1.2. But probably poor glass. Also is ther a lens which get u closer to the eye bell
Re: better lens
Post by some bloke » 29 Mar 2015, 21:56
savage wrote::thumbup: I see what u mean. Iv ordered a cheap one from china which states it's a f1.2. But probably poor glass. Also is ther a lens which get u closer to the eye bell
EDITED - wrong lens.
Would you put up a link to the F 1.2 one please?
savage
Re: better lens
Post by savage » 29 Mar 2015, 22:08
Il try not sure how to do it
savage
Re: better lens
Post by savage » 29 Mar 2015, 22:11
390878031576 item number
Radagast
junior librarian
Re: better lens
Post by Radagast » 30 Mar 2015, 04:25
This is the lens Rolaids tested as being the best.
http://www.ebay.com/itm/16mm-16-mm-CCTV ... 418ae30856
To my untrained eye it does give a better picture than the OEM item.
Re: better lens
Post by some bloke » 30 Mar 2015, 05:45
OOPS - I've told you the wrong one DUR, sorry. I'll email you in the hope you can change it.
It should be this one:
http://www.ebay.co.uk/itm/25mm-IR-Board ... 0971149583
I think aperture is measured as focal length divided by objective Lens diameter. The lens appears to be about 6mm so 16 divided by 6 makes a guessed aperture of about 2.6 if I have got that right.
Hopefully someone better informed will be along shortly.
